23 Mirage Prop info
I am looking for a used 23P Mirage prop RH. I have a 1990 Bravo one Outdrive with 454 mag. Is there any other numbers I need to worry about when I looking for a prop?
Thanks..
Thanks..
You need to prop your boat in the top half of the recommended WOT rpm range of the engine with whatever your "standard" load would be.
We have test props if you need to begin the search for the proper set up.
Brett
Brett
[email protected]
[email protected]
