25 Powerplay 595HP/595torque Prop setup help >
Old 10-07-2014 | 03:38 PM
Default 25 Powerplay 595HP/595torque Prop setup help
25 Powerplay
Just rebuilt my motor and was dyno'ed at 595/595.
Padded bottom with a notch before transom.
my propshaft is 6" below
currently 75mph at i think 6000 rpm because i'm burying the tach that only reads to 6k. Drive is getting trimmed to the moon.
i have a weird slip from 3000-4000rpm where it will just blow the prop out.... around 4200 i get bite and it will accelerate like a rocket with so much pull.
the prop on the boat is a Ron Hill 24P Signature 4-blade.
I tried a bravo prop prior to this new motor build, and the stern of the boat was lifting like crazy and getting squirrelly.
is my drive too deep? i need to go up in pitch for sure. what should i lean towards to try and get this boat to fly.
Shibby1485 is offline
Old 10-07-2014 | 07:13 PM
onesickpantera's Avatar
Originally Posted by Shibby1485
25 Powerplay
You're getting a ton of prop slip. With your prop shaft that deep I would try a mirage plus. A 27 would be a good start if youcan borrow one.
onesickpantera is offline
Old 10-09-2014 | 10:31 AM
What kind of lower unit do you have?
Black Baja is offline
Old 10-09-2014 | 10:33 AM
I think you are gonna need a 26b1. Don't go by previous test results with old power. It probably didnt have enough power to carry the bow...
Old 10-10-2014 | 09:21 PM
Stock bravo lower
Tested 28 b1 today. 5000 rpm @ 76.8
Also tested another mirage.... boat wont plane with it. Just slips and blows out. Cant get it to fall on plane no matter what I try
Dyno shows peak hp to start at 5600 and stays at peak hp thru 5900
Old 10-10-2014 | 09:26 PM
you could not be more correct, that exact same 28 Bravo acted very strange with the old power, tested the exact same prop again today, and you could pin the throttle and take your hands off the steering wheel and trim it out and drive for miles effortlessly.
I think you are on money for a 26. I am hardly getting bow lift out of the boat tho.
Old 10-13-2014 | 12:31 PM
Stock bravo lower
Mirage or Mirage Plus? Mirage Plus bites much better. Are there vent holes on the Mirage?
Old 10-13-2014 | 12:32 PM
Bravo props don't carry the bow very well. A Mirage Plus will give you much more bow lift. Also, the Rev 4 is a great 4 blade for bow lift.
Old 10-13-2014 | 06:40 PM
79.3 with a bravo 26 at 5500-5600
No vent holes on the mirage.
The boat is running very wet for sure, not getting much bow lift yet. Ran side by side w another boat at top speed.
Old 10-14-2014 | 09:03 AM
If it's a standard Mirage try to get your hands on a Mirage Plus. What rpm should you be running?
