38 fountain hp525efi's prop help
Looking for help on propping a 2006 fountain 38 lightning with twin 525's. looking at having brett over at bblades labbing a set. But my question is which props to lab? currently running 32p bravo 1's. Any one with same boat have any luck with any other props? what about going to a 5 blade?
i have 30 pitch p5x hydros on my 35 lightning t/s 525 great cruise plane and top end also run the 32 bravo 1 s i prefer the 5 blade prop
Originally Posted by blue5speed
(Post 4264636)
What kind of performance numbers are you seeing with the Hydros? I have run some but have never been able to get a set of 30's to test run, liked the way the P5x ran on mine, just had the wrong pitch. Sorry to get this off topic. |
Satisfaction,
Sorry for the delay in responding. We have returned from the Miami boat show and are trying to get back to the daily routine. BBLADES has Labbed many 4 blade propellers for these Fountain hulls and have adjusted setups for folks to 5 blade props as well for many years. If the 4 blade B1's hook up correctly, they will be the best top speed and very good all around propellers. The 5 blade props offer great low end and mid range cruise speed as well as fuel economy. The 5 blade props can slow you down on the top end if the efficiency is already good with the 4 blade props. The Hydro P5X props are just fine out of the box and can be a improvement over 4 blades in the correct situation. But, the correct Lab Finished Maximus casting will out perform a Hydro P5X every time. Satisfaction, I'd like to discuss your current performance numbers with you via phone or email. We have a test propeller program that allows you to try without buying. So, please call me at 920-295-4435 or email me at [email protected]. Thanks, Brett
Originally Posted by Satisfaction
(Post 4263683)
| All times are GMT -5. The time now is 07:08 AM. |
