BBlades question re- Bravo 3 question on Fountain forum needs a professional >
Old 03-24-2015 | 07:47 PM
Default BBlades question re- Bravo 3 question on Fountain forum needs a professional
It started out about Bravo 3s on a fountain 38 SC regarding handling while docking and the reverse direction of fountain props to create lift for max speed but not so good for docking. Then it got beyond theoretical regarding the prop direction for best perfornance with bravo 3s. Bigger leading prop vs smaller stern prop counterrotating. Do bravo 3s also spin opposite directions on fountains?
Pat Ousborne is offline
Old 03-25-2015 | 05:59 AM
i don't believe there are 2 diff rotations on bravo 3's. front prop one way and rear prop the other way is enough that they don't need to make an opposite rotation set for the other side.
dereknkathy is offline
Old 03-30-2015 | 12:34 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Forward/larger prop rotate counter clockwise and the rear/smaller prop rotates clockwise on all B3 set ups.
Brett
[email protected]
bbladesprops is offline
