24 or 25 pitch? Which one to try >
Old 04-23-2015 | 08:49 AM
Default 24 or 25 pitch? Which one to try
The boat is a scarab 300 with twin 502's and trs drives. It came with 26 pitch 4 blades, and with those, wide open full throttle was 4500 maybe 4600 rpm and 66mph. I know the motor is supposed to go to about 5100-5200 at WOT, so i got a set of 23 pitch mirage 3 blades. Just took it out on those, and 5000rpm not even wide open was only 60mph, so they're obviously too little. Do I go with a 24 or 25 now?
performancems is offline
Old 04-27-2015 | 05:18 PM
bbladesprops's Avatar
Offshoreonly Advertiser
We could potentially Lab Finish your 25 4 blades to get to 4900. If we can do this it may offer the best of all worlds performance wise. We would need to know the model of the propellers and their condition.
Otherwise, yes on testing other props in the 24-25 inch range. We do have test propellers you can rent from us to learn what you need without having to purchase the props outright.
Here is a link to our test prop program.
http://bblades.com/propeller-test-program/
Please let us know if we can help.
Thank you,
Brett
[email protected]
bbladesprops is offline
Old 04-30-2015 | 09:04 AM
thanks, I'll get in contact with you once I figure out why one motor decided to not to start.
