Prop Nut Torque >
Prop Nut Torque
Prop Nut Torque
Old 08-05-2019 | 01:44 PM
What BBLADES said. ^^^^^. 55lbs nope!!!. The nut will loosen. 2x4 in between cav plate and prop 65- 75ft lbs , i like 75 with a little grease. Check it after an outing then again after few more. Especially on new props and hubs. Its a 3/4 nut you wont hurt it.
yeah old thread i know. I have had bolts loosen a couple times on different boats, now they get tightened. Last year one guy lost a prop another guy, bolt came loose. Both of them torqued to 55. Didnt want hear my story.
veloc410 is offline
Old 08-05-2019 | 04:16 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
It's not what I say it is what Mercury says. I typically over tighten too. (without even realizing it.)
But, with a new fiberlock nut, 55 lbs. is fine.
Brett
[email protected]
bbladesprops is offline
Old 08-07-2019 | 06:44 PM
I set the torque wrench at 65 and use a touch of blue locktite as well. Let it set overnight and good to go. Never lost one yet. Have seen a set take the deep dive, not mine, at the Merc clean 55 and good to go. That marina employee adjusted his procedure on the bosses boat to 75 and red!
RaggedEdge is offline
