Mirage vs Bravo
I believe we have the same dyno guy, Full Throttle Marine. What boat do you have ? can you measure your propshaft height ? I think we can trade a lot of information.
If switching to a Bravo 1, go up in size one pitch. They tend to be over-rated. A 26p Bravo should keep you in the same rpm range as the 25p Mirage. I had to find this out the hard way. I'm running a 30p Bravo 1 with 1.5 gears and I doubt I could pull a 30p in any other prop. I think you should try one. The shorty worked great on my boat and if you do that you will almost certainly need four blades. I don't know how the shorty will work on a 29' boat though as you will lose bow lift due to less leverage (higher prop).
Yeah we do, we have talked before. I'll have to measure next time I'm with my boat. Maybe someone knows stock 6.2 prop height.
I also agree the reported 9% slip can potentially be left alone unless you are desiring better cruise speeds or planning.
Brett
[email protected]
[email protected]
My desire is getting the most out of what I have. I'm 7 3/8 deep and wondering if I install -2 Imco's what prop would be looking for. In a somewhat perfect world... And will a -3 Imco bolt to a Bravo1?
Agreed. Every application desires certain propeller geometry for certain performance goals. One prop design will propel a boat but specific goals can improve by changing props.
Brett
Brett
The -3 should work. Contact IMCO with questions.
Brett
[email protected]
[email protected]
For a -3 lower, you either need an Imco upper designed for it or you need to have a stock Bravo upper cut and modified.
http://www.imcomarine.com/cal_store/...e-3-black.html
Raising the propshaft 3" is a ton. I'd go -2's max.
