Prop Size >
Prop Size
Prop Size
Old 07-13-2015 | 10:54 PM
Default Prop Size
What prop should a 650 HP 540 1.5 Bravo spin on a 25' boat 4800lbs?
It currently has a Bravo 1 .4blade 28 doesn't seem like correct
Thoughts?
RBeyer is offline
Old 07-13-2015 | 11:17 PM
That should be about right.
It really depends on what rpm the engine makes peak hp at to know for sure.
Griff is offline
Old 07-13-2015 | 11:39 PM
Thanks, owner claims are 5600
We will water test and GPS
RBeyer is offline
Old 07-15-2015 | 10:19 AM
You would probably have more luck at least giving the make/model of the boat.
chewymalone is offline
Old 07-15-2015 | 10:30 AM
Dave M's Avatar
Veteran: Navy
^^ What he said.
I can turn a 28P Bravo to the rev limiter (525efi) in a 30' / 4800lb boat.
Dave M is offline
Old 07-21-2015 | 11:25 AM
Passed on the boat but it was a 1997 Mirage 257 for others info
RBeyer is offline
