-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Prop decision (https://www.offshoreonly.com/forums/prop-talk/328921-prop-decision.html)
the mayor 07-26-2015 10:08 AM
Prop decision
27 Fountain non step dyno sheet 712hp 692 ft lbs torque. At 5400rpm. I was running a 1.36 bravo 24 pitch labbed bravo prop.
Out drive broke I put a 1.5 drive on it and as you can imagine it will spin it to the moon. I have been looking for a 28 pitch and have found a 31 labbed . I know the 31 was for a specific boat or set up do you think it is to much for my setup.
I spent a bunch on the engine over the winter trying to get by until I can get the 1.36 back
Padraig 07-26-2015 10:12 AM
I have a stock 30 inch LH Bravo One for sale. Might be just the ticket.
Padraig
the mayor 07-26-2015 10:14 AM
Padraig
Need RH
Padraig 07-26-2015 10:26 AM
OK, thought maybe you were running a lh as I have heard Fountains often like lh props.
Good luck and have fun testing as we are finally getting good weather.
Padraig
the mayor 07-26-2015 02:10 PM
Padraig
Same here been 5 weeks since it was in the water. Hopefully it's going to get better
Griff 07-26-2015 08:19 PM
I would use BBlades test program.
Too Stroked 07-27-2015 11:05 AM
Originally Posted by the mayor (Post 4334251)
Need RH
Every 27' Fountain we ever sold came from the factory with a LH prop.
RNGRDVE 07-27-2015 11:15 AM
I have a 28 Spinelli that I borrowed to try out on mine but haven't had time yet and I'm getting a 28 Bravo to test soon also. Let me know if you want to try one and we can meet up sometime if the level and debri gets better.
the mayor 07-27-2015 02:57 PM
Sounds great let me know when and where
RNGRDVE 07-28-2015 02:08 PM
Not sure when we will be out again but if you are headed down this way before we get out let me know and I can meet you somewhere. I don't get on here too often but Tracey knows how to contact me if you don't already have my #.
