2X SSM 5 Props needed >
Old 07-30-2015 | 08:02 AM
Default 2X SSM 5 Props needed
Anyone know of or have any SSM V or VI props I could use for a day? Would be willing to pay a non-refundable deposit just to get an idea of what I need. I will take care of shipping, or come pick up.
16.5"-17" dia
29-34 pitch
4 or 5 blade - cleaver style prop
Also if anyone has this setup, what is a good target prop?
1990 Top Gun - non-stepped
SSM 5 drives, even with the bottom, on 12" boxes
Notched transom
1.5 : 1 ratio drive
1080 HP per side @ 5600 RPM
Can anyone point me in the right direction? I am striking out here. Thank you!
-Justin
frickstyle is offline
Old 07-30-2015 | 12:11 PM
Team Archer's Avatar
I have built a couple of 38 Scarabs and Cigarettes with Speedmasters IIIs Vs VIs the 38 straight bottom boats with around a thousand HP on a 1.50 ratio we run a 17.5 dia 29 to 31 pitch depending on the drive height and weight of the boat. I would recommend that you start with at least a 17.5 dia prop big V bottoms love diameter. I have a set of 17.5 x 31 4 blades that you can try but they are not for sale they belong to a boat under restoration so we wont be needing them any time soon.
Team Archer is offline
Old 07-30-2015 | 12:46 PM
^^^ That's pretty valuable info, thank you. Have you run 5 blades on that setup? Better results with the 4 blades?
I am probably more interested with planing ability, cruise, and handling than all out top speed.
Old 07-30-2015 | 01:12 PM
Saber Marine / Doug, your PM is full,,,
in response to your message.
OK, what pitch? I am going to test hopefully this weekend. I will let you know if I plan to purchase after I know more about what the boat likes, I appreciate the response!
-Justin
Old 07-30-2015 | 01:28 PM
bbladesprops's Avatar
Offshoreonly Advertiser
frickstyle,
We have a test program just for your needs. I advertise and talk about it all the time. The program let's you try without buying. Here is a link to the program. Call us if we can answer any other questions and set you up in the program.
http://bblades.com/hering-6-offshore...-demo-program/
Thank you,
Brett
[email protected]
bbladesprops is offline
Old 07-30-2015 | 01:36 PM
Brett,
Yes, I understand that option and have spoken with you. Thanks, just can't justify the expense right now for the Herrings. Maybe that will change here soon. I will keep it in mind.
Old 07-30-2015 | 01:56 PM
Thank you for the response.
My intention was not just to sell props but to allow you to test props for a fee as you stated, and then use that base line information to better shop for the props you desire.
Let us know if we can help in the future.
Brett
[email protected]
Old 07-30-2015 | 04:44 PM
we have run both 4 and 5 blades the higher the x the more blades help you get on plane easier. Just letting you know what I have that you can test with.
Old 07-30-2015 | 10:24 PM
bck's Avatar
bck
Charter Member#568
Gil mentioned he gave you my number. I've got a set of 17x 30 4 blades. Not for sale but you can try them.
Straight bottoms and flat decks
bck is offline
Old 07-31-2015 | 06:56 AM
Thanks guys, should have a pretty good direction next week after testing, I'm all set until I find out how it reacts to these test props.
