Need prop advice >
Need prop advice
Need prop advice
Old 08-22-2015 | 12:14 PM
Default Need prop advice
I need more prop plus would like less transom lift if possible thd Daytons runs way to flat..... Maybe even something to let met get mote trim?
Anyways currently spinning 30p Bravo 1's at 6,000 rpm easily on limiters.... The 33 has approx 900 hr per side and running 1.5 gears.... Bravo Teague drives with extension boxes
Would like any help or suggestions... Need plan before buy or start trying props....
stormbauer is offline
Old 09-02-2015 | 06:25 PM
bbladesprops's Avatar
Offshoreonly Advertiser
We can offer you test propellers as well as many Lab Finishing options to aid in transom leverage as well as bow lift. We have propped many, many Daytona's over the years. There are some tricks to them as well as very touchy "X" dimensions.
Call anytime and we can offer some options.
Thank you,
Brett
[email protected]
bbladesprops is offline
