Prop myth or truth?
In a conversation with a friend I was told that a 32p bravo1 is the most efficient right out of the box of the B1 line... any truth to this?
I heard the exact opposite, that they could never get it right. Who knows
i heard that was the highest pitch, after a32 they start slapping the water instead of cutting and pushing it.
I heard the same as post #1
Matt and Julie from Throttle Up used to say Bravo 28....on a regular basis.
And that's all I have to add on that. LOL. |
I kinda like the 30's.
The 34 and 36 are the only 2 props that are actually 15.25" diameter as advertised. The 34 was actually our first attempt at a 32 pitch Bravo 1 but was bumped to the 34 cause it was build more true to pitch than the 22-30. The 28 is actually the smallest diameter of the family clocking in at 14.75-14 7/8. The whole family is about 1 inch lower in pitch than marked. Even with all their deviations, they have been great performers. Brett |
Brett, is there a minimum ventilation plate to prop tip clearance we should stick to, and what is the Ideal clearance?
thanks in advance
Originally Posted by bbladesprops
(Post 4352379)
The 34 and 36 are the only 2 props that are actually 15.25" diameter as advertised. The 34 was actually our first attempt at a 32 pitch Bravo 1 but was bumped to the 34 cause it was build more true to pitch than the 22-30. The 28 is actually the smallest diameter of the family clocking in at 15.75-15 7/8. The whole family is about 1 inch lower in pitch than marked. Even with all their deviations, they have been great performers. Brett |
I messed up my diameters above. I did edit them however.
Max diameter is aprox. 15.5". .25" is the min. clearance but with thinned props I like a little more. Brett |
Interesting, so what is the actual diameter of a 30 and 32 respectively?
offshoredrillin,
These 2 casting come in at 15" diameter. Brett |
| All times are GMT -5. The time now is 11:42 PM. |
