RPM Change >
RPM Change
RPM Change
Old 09-10-2015 | 04:07 PM
Default RPM Change
I'm looking for a general idea on how many RPM Change there would be using bravo 1 4 blade props going from lets say a 28 to a 30 to a 32 would your say 300rpm per each? stock props no special Lab stuff.
C1000 is offline
Old 09-10-2015 | 05:16 PM
It will worsen as you step up..as you start to lug the engine with every increase. I use a 250 rpm but I would consult B Blades. Possible they still have a testing program if your ready.
http://bblades.com/
cmattj is offline
Old 09-11-2015 | 01:00 AM
There is about a 200 rpm change for every inch of pitch change using the same model of prop.
Griff is offline
