hydromotive mounting >
Old 09-15-2015 | 01:45 PM
Default hydromotive mounting
have a solid hub bravo 1 hydromotive prop I am going to try, see nothing for a lock ring on this, do they use a lock or just a lock nut ? thanks Rob
ezstriper is offline
Old 09-20-2015 | 05:11 PM
Had the same issue. They require a spacer that has splines and locking tabs like a torq flo. CP sells them by the pair???? Amazon has singles though, about $15.
Cole2534 is offline
Old 09-21-2015 | 05:44 AM
thanks...ended up cutting down one from a bravo 1 mount worked fine
Old 09-22-2015 | 09:53 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Here you go for future reference.
http://bblades.com/shop/accessories/...inuity-washer/
If it is propeller hardware, we have it. If it isn't on the web site we still have it.
Thanks,
Brett
[email protected]
bbladesprops is offline
Old 09-22-2015 | 03:28 PM
thanks Brett
