-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Hub Help (https://www.offshoreonly.com/forums/prop-talk/334371-hub-help.html)
ADub 02-07-2016 02:47 PM
Hub Help
I have a 2006 B1X drive with a Bravo Prop and Flo Torq hub. I purchased 835258Q2 hub kit to replace the existing hub. Nothing majorly wrong with the existing, but the thrust washer was grooved and I needed a new nut/washer, figured Id refresh the entire hub assy. The existing spacer has a brass sleeve in side, the new spacer has a plastic sleeve inside and the overall length on the new sleeve is maybe 1/8" shorter. When I set the new sleeve on the shaft, there is significant play all around. Im wondering if this plastic sleeve compresses when you install it, removing the play or if I have the wrong part? This appears to be the correct hub for this application, but its obviously been revised from the part I currently have.
class6 02-07-2016 03:22 PM
Is going all the way on to the shaft. And are the splines lining up and engaging correctly
ADub 02-07-2016 03:23 PM
Yes and Yes
class6 02-07-2016 03:29 PM
What size shaft do you have? I'll be home in a few hours I can check my part #s. I just bought a few for the 1 1/4 shafts
ADub 02-07-2016 03:57 PM
1" shaft
class6 02-07-2016 05:28 PM
Sorry. All mine are 1 1/4.
ADub 02-15-2016 10:45 AM
So I still have the question, does this plastic insert deform when you torque it so that the hub centers on the shaft?
bbladesprops 03-01-2016 02:50 PM
ADub,
Something isn't adding up here. First of all, a 835258Q2 consists of a thrust washer, a "short" stainless steel insert, a brass or Stainless aft adapter, a lock washer and a nut.
If you have a plastic insert, the kit you have isn't the part number you mentioned.
Next, the plastic or stainless insert needs the aft adapter to mesh to the splines on the prop shaft. The plastic insert does not compress but does need to be seated in the prop bore.
It might be easier for you to call us and we can better explain this over the phone.
Brett
ADub 03-01-2016 02:54 PM
Brett,
My description may be confusing. The large metal spacer (850821) on my existing hub has a brass liner. The same part on the item I ordered (850821-1) has a plastic liner. The entire spacer isnt plastic, but the ID is.
The black liner in the spacer in this link is what I am referring to.
http://www.ebay.com/itm/OEM-Mercury-...dWr35X&vxp=mtr
bbladesprops 03-01-2016 03:19 PM
850821 is called the hub insert or drive sleeve. We never made one with a brass liner. It was always delrin plastic since the beginning. It does protrude slightly and will press in after torquing (or you can seat it with a mallet).
Also, that delrin liner/bushing is tapered and only goes in one way.
You could actually use the insert without the bushing as the aft adapter and the thrust washer will center the assembly as long as you don't use a Q1 kit where a Q2 is needed.
Brett
ADub 03-01-2016 05:59 PM
Thanks Brett
