Mirage prop difference? >
Old 06-30-2016 | 06:12 PM
Default Mirage prop difference?
I have 2 props for my boat. Both are 23 pitch. One is a mirage plus. The other is a mirage. The mirage seems to accelerate better than the plus. What's the difference between the two?
Uberlord is offline
Old 06-30-2016 | 06:40 PM
Cupping. The Mirage Plus has more cup. The Mirage will generally run a little higher RPM in the same pitch, with slightly less bow lift.
Speedracer29 is offline
Old 06-30-2016 | 06:45 PM
Also, the Mirage will have a rubber hub and the Plus will have the Flo-Torq hub and PVS system (adjustable holes for more slip to get the RPMs up on take off via ventilation).
Old 07-01-2016 | 01:38 AM
I believe the Plus also has a slightly larger blade area.
Trash is offline
Old 07-01-2016 | 01:16 PM
I've had both. I have grown to like the regular Mirage more and you do see more rpm with the regular Mirage vs the Plus.
AWOL is offline
Old 07-01-2016 | 08:45 PM
Thank you for the info. The PVS I didn't know about. My boat is sluggish getting on plane with the mirage plus. I will good with the vents and see what happens. Something else to play with. I like tweaking and tuning things.
Uberlord is offline
