Donzi 22 ZX non step, prop change >
Old 07-12-2016 | 01:01 PM
Default Donzi 22 ZX non step, prop change
Running a 1997 22 ZX (no stepped hull) with a 454 Magnum and stainless marine manifolds. Boat currently has an untouched 23P mirage plus (early style so no PVS) and runs 67 mph on GPS just touching the limiter. At near max trim it will blow out.
Considering a 25P mirage (non-plus) prop to drop a few RPM off the top end. I know the plus props have more cup so any idea what kind of RPM difference I'd see? Any guess on what will be the better prop?
Top-Gun is offline
Old 07-14-2016 | 06:22 PM
bbladesprops's Avatar
Offshoreonly Advertiser
RPM may drop 500-550.
For speed the 25M+ after baseline specs are used to create the proper Lab recipe.
Brett
[email protected]
bbladesprops is offline
