Propeller for 33zx >
Propeller for 33zx
Propeller for 33zx
Old 10-31-2016 | 07:02 AM
Default Propeller for 33zx
Hi there!
I own a 33zx Donzi, 1995 with twin 502 Mercruiser Magnum EFI engines with Bravo One Gears and currently furious about changing my propellers.
its currently running on Laser II 23 Pitch and getting 62 Mph WOT @4600RPM,
wondering what propeller i could upgrade to, please help!
AlOstad_84 is offline
Old 10-31-2016 | 10:59 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Ok, what is your goal?
Are you looking for speed or low end or overall performance?
Brett
[email protected]
bbladesprops is offline
Old 10-31-2016 | 11:05 AM
Hi Brett,
Basically a good all around propeller.
Heard the 28 pitch bravo one propeller should do it? Any other suggestions and why? Thanks
Old 10-31-2016 | 11:57 AM
I would concider 21 Revolution 4's.
Or, Labbed B1's.
We can set you up with stock test props if you would like.
Brett
[email protected]
Old 10-31-2016 | 12:29 PM
Labbes B1?
Why go smaller pitch? Already with my 24's I notice so much ventelation ..
Old 10-31-2016 | 12:55 PM
Originally Posted by AlOstad_84
Labbes B1?
Because you are not getting enough rpms at wide open throttle. You should be spinning 502mpi's at 5000 rpms.
Griff is offline
Old 10-31-2016 | 03:50 PM
What Griff said.
Also, the 4 blade props have more blade area and will decrease the amount of ventilation and potential slip %
Your slip is fine but the venting can be fixed.
Brett
[email protected]
Old 10-31-2016 | 04:24 PM
I messaged you back the other day don't know if you got it. I am running 28s but I have the twin step hual and 500efi's. Brett and griff are right you need more rpm.
1989mach1 is offline
Old 11-08-2016 | 04:45 AM
Thanks guys! I'll try to get some for trials and will update you.
Old 11-08-2016 | 04:46 AM
Hi Brett, unfortunately I'm not in the USA ..
what's your policy for overseas? Thanks!
