BBLADES Releases 2 new BBLADES propellers to the marke! >
Old 03-09-2017 | 03:19 PM
bbladesprops's Avatar
Offshoreonly Advertiser
resent
Still didn't get it. Please send to
[email protected]
Request it be forwarded to Brett
Thank you.
[email protected]
bbladesprops is offline
Old 03-09-2017 | 03:45 PM
Originally Posted by conneroutlaw
hey this jj from Dunkirk with the Baja, please send me your new email address. I tried emailing you and got a returned email
thanks jj
my email is [email protected]
Did your email go through? Did you get a response.
I'm starting to wory we might have a server issue?
Brett
[email protected]
Old 03-09-2017 | 04:30 PM
Originally Posted by NWPC
Labbed B1 for Rick Andersen
Rick, Because your slip numbers are so good with the stock 26 B1, 8.6%, it will be difficult to determine if the 4-SPEED will out-perform the Labbed Bravo.
The only way we will know for sure is to test them back to back. We have found the stock 4-SPEED to out-perform the stock Bravo 1 in the majority of tests. We are still learning on the Labbed versions of the 4-SPEED. If the 4-SPEED out-performs the B1 in stock form, it should do so in Labbed form. But, each application is different.
So, we can definitely test the 4-SPEED on your hull.
Thank you,
Brett
[email protected]
Old 03-09-2017 | 05:39 PM
NWPC's Avatar
Thanks Brett
It was just a thought.
I am sure the Labbed B! will work great.
NWPC is offline
Old 03-09-2017 | 06:13 PM
offshoredrillin's Avatar
Brett
i got no bounce back this time... i had server issue a few weeks back, but all worked out.
offshoredrillin is offline
Old 03-09-2017 | 07:17 PM
Brett
Brett, I think he was directing that to me.
Padraig
Padraig is offline
Old 03-16-2017 | 12:58 PM
VoodooRob's Avatar
Talked to Brett today and we are going to get a set of the new 4 Speed for our boat. The 32 Maximus on there now were sent to him to get worked, we purchased the boat end of season last year and props didn't look good. Brett gave the Maximus the once over and it was a thumbs down for repairs. Will report back on how the new props perform, etc.
VoodooRob is offline
Old 03-19-2017 | 08:10 PM
looking forward to your results, searching for info on replacement for the same props .........good luck
midwest272 is offline
Old 03-20-2017 | 02:19 PM
Rob's Maximus's were unrepeatable do to a 4 inch crack and some serious gouging ground into the blades from the last guy who worked on them.
Basically non cost effective.
should be picking up a truck load of castings this week!
Brett
[email protected]
Old 03-20-2017 | 02:46 PM
VoodooRob's Avatar
Brett
Ok let me revise my trying to be polite to the previous owner. Looks like Fred Flintstone repaired the props and Ray Charles was in quality control.
