Signature propellers >
Old 09-18-2017 | 04:19 AM
Default What size of prop should I be running
I have a 32ft Sleekcraft Heritage with twin 500EFI's with bravo 1's with 4 blade 30 pitch props, at WOT I'm running at 5200 RPMs at 80mph with trim at about 50% up. When I get out of the hole the props start to cavitat and I have to back out of the gas. Should I jump up to a 32 pitch 4 blade?
Edmacias is offline
Old 09-27-2017 | 12:27 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Originally Posted by shunter2005
Brett - If you reduce the 5 blade prop diameter to get less stern lift, will that affect bow lift (get more, the same or less)?
Because the stern is not lifting as much, the prop will stay deeper with more water volume above them increaseing potential leverage on the transom.
That leverage is what carries the bow. So yes, you should get more bow lift.
Removing diameter requires matching blade area and thicknesses to original spec.
Brett
[email protected]
bbladesprops is offline
Old 09-27-2017 | 12:30 PM
No.
I would rather see a conservative Lab done to the 30's with a cup adjustment to hold the water to the blades better during planning. You still have a 200 rpm window till you get to the rev limiters. The adjustment should be able to be done while gaining 0-100 rpm and increase overall performance.
Brett
[email protected]
Old 10-03-2017 | 10:02 AM
Originally Posted by bbladesprops
BBLADES 4-SPEED (sterndrive application) from BBlades Professional Propellers
That is a link to the BBLADES 4-SPEED.
Dropping the drive will give more bow lift.
It will also increase drag and affect speed. You will also get meore stern lift with the 5 blade unless the diameter is reduced.
Brett
i like that 4 speed .its more round eared, correct. Do you offer any type of trial program or possibly come there and try something
veloc410 is offline
Old 10-03-2017 | 11:04 AM
Yes this is a round eared propeller.
We do offer a test program where you can try the prop for $55 for 15 days without purchasing the prop.
This way you know what you are buying prior to purchasing.
Here is a link to the program.
BBlades Propellers | BBLADES Propeller Test Program
Brett
[email protected]
Old 10-03-2017 | 05:40 PM
Nice definitely interested. This coming spring .cant so it now .had a new valve guide come loose so engine coming out now
veloc410 is offline
