What prop should I be running?? >
Old 07-05-2017 | 06:01 PM
Default What prop should I be running??
This boat is new to me and I started to see what kind of speeds I can get out of it after owning it now for a couple months. Its a 288 Sunsation Intimadator that has a 377 stroker with a Bravo 1 drive and 22P four blade Bravo 1 prop. This is whats happening as I went for top speed...The RPM's keep climbing past 5500 and would likely pass 6000 rpm"s but I backed off as soon as it was still climbing at 5500. The boat planes out amazingly fast with Zero effort and the gas mileage seems pretty darn good aswell!! I usually run 35 MPH at about 3500-3600 rpm. This boat must have the wrong prop!! Or is the Tach out of wack?? I believe Max RPM on this motor should be 5200 rpm's
iroc fan is offline
Old 07-05-2017 | 10:17 PM
Tach is off assuming the motor ECM hasn't been altered.
What is the out drive ratio?
Trash is offline
Old 07-06-2017 | 04:54 AM
iroc fan is offline
Old 07-07-2017 | 03:00 PM
What top speeds are you seeing? Most likely could go to a 24 or possibly 26.
Mr Maine is offline
Old 07-07-2017 | 08:48 PM
I dunno. Thus is a 28 foot boat with a small block in it.
dereknkathy is offline
