lab props >
lab props
lab props
Old 08-08-2017 | 10:32 AM
Default lab props
ive tried so far multiple lab probs from companys and honestly haven't noticed much difference vs my stock bravo one 4 blade prop , anyone getting good gains of lab props vs non lab? just always hoping for more when you spend 1200 on a prop lol
daniel475 is offline
Old 08-08-2017 | 12:06 PM
Are you buying them new and already labbed, or starting with a fresh prop and labbing the final needs out of it. to get it right you need to try prop after prop, find what the boat likes then go from there. the next day the water changes and it no longer works. different water different props. Everybody should have a few props for different water conditions. Then its up to you to pick the best one for that day. Build yourself a big shelf and keep racking them up
class6 is offline
Old 08-08-2017 | 01:42 PM
Default hey
buying brand new and having them labbed fresh ! so far not seeing any difference vs the stock props
Old 08-08-2017 | 02:04 PM
You should run the stock the lab is to adjust what you need changed
class6 is offline
Old 08-25-2017 | 11:09 AM
bbladesprops's Avatar
Offshoreonly Advertiser
What is your set up?
Labbed props are best done with a specific goal in mind. Not all boats and set up repond but most do. 1-3 mph is the common speed increase but more can occasionally be had.
I don't know if we have worked with you but we can surely offer some advice.
Call me anytime and let's see what is going on.
Brett
[email protected]
bbladesprops is offline
