Props
Old 01-09-2018 | 07:54 PM
I have been wanting to try a pair of bblades 4speeds I here they pull great numbers
1989mach1 is offline
Old 01-09-2018 | 07:56 PM
I was going to this summer but ended up getting imco lowers so need to see what my numbers are going to be now.
Old 01-10-2018 | 01:31 AM
Originally Posted by Chinewalk
Any recommendations on another prop to pick up some rpm and speed? I feel it has a little more.
Maybe a set 26 Bravo's. The actual real pitch is closer to 25.2.
With one less blade, you should pick up some rpms and maybe speed. Your slip % might just go up though.
Griff is offline
Old 01-10-2018 | 06:42 PM
T-Mone's Avatar
T-Mone
Chinewalk
Griff is right about the 26 bravo 1''s. They should carry the bow a little better and loosen her up a bit which may get you some rpm's and a couple miles per hour. They won't get you on plane like the 5 blades but your drives look pretty deep so I don't think you will have any trouble. Are you turning your props in or out on that boat now? Also if I remember those motors were built with blowers and then went to NA, i'm thinking low compression and you may just be running out of power as well. Your boat looks beautiful and mid 70s' ain't bad especially when your out running in some big water.
Have fun with her and I hope to see you on the water this spring.
T-Mone is offline
Old 01-11-2018 | 03:31 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Testing our 4-SPEEDS is a great option.
Brett
[email protected]
bbladesprops is offline
Old 03-23-2018 | 08:05 PM
Brett
Brett can I test a set?
Chinewalk is offline
Old 03-23-2018 | 08:09 PM
Originally Posted by T-Mone
Chinewalk
PM me. I would like to talk more and meet on the water.
Old 03-24-2018 | 10:12 AM
Brett
Yes, just give us a call and we will arrange the shipping at your desired timeframe.
Brett
PS We have modified the the test program. Test fees charged for testing BBLADES branded propellers apply toward purchase of the BBLADES castings.
[email protected]
Old 03-24-2018 | 10:47 AM
Brett
Thank you!
