Prop size >
Prop size
Prop size
Old 01-20-2018 | 11:32 PM
Default Prop size
I have a 1996 27’ Advantage Victory, 454 MPI with 425 hours on the motor. I currently run around 50 MPH at 5000 RPM.
This is my first IO that I’ve owned. It currently has a 24 pitch prop. Question is. Is the RPM to high for a stock motor, I know my prop is a little worn so I’m thinking of replacing it with a 26 pitch, is that to much prop and would a cleaver style be any better? Any other prop suggestions?
My other boat was a 21 Schiada with a 525 and a turbo 400 with a C500 vdrive, untill kids came along.
Skytrak10054 is offline
Old 01-25-2018 | 08:44 PM
If your drive ratio is 1.5:1 then something is off. We need your drive ratio and GPS speed to make any further recommendations.
Trash is offline
Old 01-26-2018 | 01:13 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Your slip % or propeller inefficiency would be over 30%. This is possible but poor.
If it is accurate, something is wrong.
Verify rpm and gps speed. We assume your gear ratio is 1.5:1.
Brett
[email protected]
bbladesprops is offline
