Prop Hub Play
Over the weekend I changed props and noticed one hub had some play within the prop and the other was rock solid. Do these things wear out? Flo-Torque II Solid Hub Kit 1.25” shaft. |
I replaced 2 of them in past 2 years. They must wear out. Can't see how but new ones where tight....
Originally Posted by rvtransport
(Post 4630557)
We carry snubber kits which can snug up the inserts.
Here is a link. https://bblades.com/shop/accessories...-strip-kit-hd/ Brett |
ever had a brand new hub fit loose in a prop?
Originally Posted by LTZCrew
(Post 4707212)
Yes. The hub and propeller are cast. There are tolerances and if they are each at max of the opposite ends we can have additional play. This is of no concern since we still have a square plug in a square hole. Make sure the prop nt is tigh and there should be no prop rattle. Brett |
