270 sundancer propeller choices >
Old 07-03-2018 | 03:56 PM
Default 270 sundancer propeller choices
In addition to my sonic I have a 1990 270 sundancer with a single 340 hp 7.4 1.50 Bravo 1 drive
WIth the 15 P 3 blade prop that the seller just
threw on there I am getting 5500 rpm wot in fresh water. It seems like I have to maintain 3500 just to keep it on a plane.
What are the best choices for a 5800# 20deg dead rise boat ? I will use it is salt and fresh water.
19P mirage? 4 blade?? Sea rays prop matrix doesn't list the 270 in 1990 It does however list a 290.
Any help will be appreciated very much
schurgervt is offline
Old 07-03-2018 | 05:17 PM
Think your tach is off, the 7.4 max rpm (unless work has been done) is 5000
Can you get a handheld tach and get your max speed at WOT using a GPS or one on a phone?
AllDodge is offline
Old 07-03-2018 | 06:39 PM
What limits the rpm the ignition module? The engine is an 86 v drive 340 hp std rotation version
Old 07-03-2018 | 06:55 PM
You should have a TB-IV and of which does not have a rev limiter, but going above max WOT I can see the motor coming apart
AllDodge is offline
Old 07-09-2018 | 07:47 PM
It was still OK to see what the 15 would do. Now OP knows he needs a 19" 3 blade or such. For a heavier boat like that maybe a 4 blade 18.
NHGuy is offline
