Prop Ideas
Keep in mind that 34 Bravo's perform somewhat differently that other Bravo pitches of Bravo props. BBlades had posted the specifics in older threads. That is not saying they would not work fine on your boat though.
First thing I would do is run your props and then see what you can find to borrow in the 32-36 range locally for testing. Maybe even look for 30-32 5 blades to try. Then use BBlades test program if needed.
Wouldn't be able to spin those without shorties. Baseline with stock 32s is 5300 RPM we would like 5400 to 5500. A little tweaking and should be there.
