Do I have the right prop? 33 Fountain lightning >
Old 09-27-2020, 07:53 PM
Default Do I have the right prop? 33 Fountain lightning
I have an 08 33 fountain lightning with 496ho's , 1.65:1 ratio and maximus 32x15 5/8, My performance sheet says it came with 33 maximus ran 84 and turned 5050 rpm. I find this hard to believe since with the 32 props on there i have not turned more than 4650 rpm. and run 79mph, both engines are turning same rpm. Any help would be appreciated.
fcs1965 is offline
Old 09-28-2020, 07:41 AM
That's because the performance report was based on the magic waters of the Pamlico River! ;-)
Fountain may have labbed the original props, as well. Call BBlades and tell Brett what your seeing - he can get you a few more RPMs with labbing.
ALL_IN! is offline
Old 09-28-2020, 08:04 AM
1.65:1 ratio and maximus 32x15 5/8, 32 props on there i have not turned more than 4650 rpm. and run 79mph.
Only 7,7% slip?
plavutka is offline
Old 09-28-2020, 08:45 AM
is that good or bad?
fcs1965 is offline
Old 09-28-2020, 09:03 AM
i think i have the original props
fcs1965 is offline
Old 09-28-2020, 04:04 PM
Well, if current props are 32's, and you have the original 33's - then put the 33's back on and report back.
ALL_IN! is offline
Old 09-28-2020, 06:56 PM
i think the originals are 32's even though th sheet says it had 33's. 33's would turn even less rpm
fcs1965 is offline
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information -
Copyright 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
