-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Stronger Prop Hubs? (https://www.offshoreonly.com/forums/prop-talk/378110-stronger-prop-hubs.html)
PQ290Enticer 01-14-2023 02:00 PM
Stronger Prop Hubs?
I have Bravo -1 props This upcoming season I will be running 500hp engines. Just looking around randomly at different sites etc. and noticed on Teague's site that they mention something about 400hp hubs. This is something I never thought about. Is this something I should be looking into? They make different hp hubs? Also, and I think this is the most important question, how deep does the "up the hp rabbit hole" go? Is there a list somewhere of all of the things you will need to upgrade because of the hp increase? Thanks for your comments and help.
F-2 Speedy 01-14-2023 02:09 PM
NO
PQ290Enticer 01-14-2023 02:16 PM
End. Thanks F-2.
bencini231 01-14-2023 02:23 PM
Your going to break something in the drive before you break that prop hub.
PQ290Enticer 01-14-2023 02:26 PM
I don't know why they called it out on their site. Maybe just pointing out that they are standard 1" hub props?
F-2 Speedy 01-14-2023 02:45 PM
because their in the business to sell parts, Im sure there are plenty of guys running 600 - 800 hp through bravo style solid hubs
xlint89 01-14-2023 09:02 PM
I'm guessing you're referring to the plastic replaceable hub. (STD HP)
They then offer the aluminum replaceable hub for higher HP. (400 HP+)
The other possible problem will become the Bravo 1 out drive. Some have claimed you can go 500-550 HP before things brake. (and careful throttle control) The first HP 500 (carb) came with a Bravo 1. After that, the HP engines started coming with the Bravo 1 XR.
bajaman 01-15-2023 09:22 AM
Just as a semi-related observation and subsequent question...but my old Baja 208 Islander had the Yamaha Hyrda-Drive ( 454 Chevy coupled to Yamaha's unique hydraulic clutch outdrive) and it used SOLID hub props...there were no rubber inserts. I have seen from time to time similar 'solid hub' props for sale. What is the advantage/disadvantages? I know on the Hydra-Drive the hydraulic clutch protected the outdrive in the even the prop struck something.
PQ290Enticer 01-15-2023 10:05 AM
Bajaman, That's interesting. Not that I am aware of everything boat related. Far from it but I never heard or seen that Yamaha drive system. I'm assuming you were not running a high hp mill in that 208? Was that drive pre Bravo-1? Was that considered at the time an "Upgrade" from an Alpha?
My observation of the solid hub stuff is probably what you are thinking. No way for a pressed in or drop in hub surviving really high hp and torque?
bajaman 01-15-2023 10:24 AM
There's a huge story behind Yamaha's foray into outdrives in the U.S., and how Mercruiser essentially freaked out and sued them and ended their U.S. presence; these outdrives are still very popular in Europe and the U.K., especially with the RIB crowd as they can withstand immense amounts of torque that the diesel powerplants ahead of them produce.
My 208 had the basic 330 hp 454. A couple of pics:
https://cimg2.ibsrv.net/gimg/www.off...57c1103dbd.jpg
https://cimg6.ibsrv.net/gimg/www.off...6b2e1d147a.jpg
