Propeller question >
Propeller question
Propeller question
Old 02-23-2023 | 12:22 AM
Default Propeller question
OK guys, I have a 383 mercury engine coupled to a bravo drive. The engine puts out about 350 hp in the drive ratio is 1:50. The boat is 19.5 foot. Any ideas on the pitch and propeller diameter I should use? Should I call mercury racing and ask?
GeorgeSpencer is offline
Old 02-23-2023 | 04:35 PM
I had a 19' Checkmate with a decent 400sbc. It made an estimated 350plus hp. The best prop we found was a 27" Mirage plus from Merc. We could turn that just over 5K and had great bow lift.
miller high life is offline
Old 02-23-2023 | 04:57 PM
SB
What engine was in it before ? What prop ? How did it do - planing, top speed at what rpm ?
SB is offline
Old 02-23-2023 | 06:02 PM
I'd start with a 23" Mirage Plus, and go up from there. You SHOULD be able to pull 4800 - 5000 rpm, and if so, go up to a 4 blade Rev 4 in 24", see what happens. DOUBTFUL you'd be able to do a 25" Mirage Plus but worth trying for top end, but the hole shot would probably suck beyond belief.
Baja 252 Islander
bajaman is offline
Old 02-23-2023 | 06:10 PM
https://www.mercurymarine.com/en/us/...lers/selector/
speicher lane is offline
Old 04-24-2023 | 05:13 AM
Default propeller resource
You might give Rich Junker over at leading edge propellers a call he's very good at propping boats.
Capt. Lenny is offline
Old 04-24-2023 | 09:38 AM
In boat that small the tempest plus might also work well. In my 22ft hull with 380hp 383cid, mirage was the worst ever prop, and tempest worked perfect.
JaniH is offline
Old 04-24-2023 | 09:29 PM
I was thinking the same thing. So far the fastest prop on my 22' Baja has been a worked over Tempest.
Smitty275 is offline
Old 04-25-2023 | 12:23 PM
With a small block and a 20 ish foot boat starting out in a 19-21” 3 blade will be the best starting point. Laser II or there about.
Trash is offline
