Prop Tip Damage >
Prop Tip Damage
Prop Tip Damage
Old 05-10-2023 | 05:42 AM
Originally Posted by PQ290Enticer
So the question is, are you going to leave it that way?
PQ290,
For now, yes. I will file the burrs off the non-working edges, but I'm not going to take the time to repair it for what little damage there is. I am on the hunt, though, for a backup Bravo1 28P prop. I currently have a 26P in a pocket under the cuddy, but would like the backup to be the same as the running prop. This will also give me the opportunity to do the repair, and maybe lab work, to the worse of the two.
Thanks. Brad.
Brad Christy is offline
Old 05-10-2023 | 08:08 AM
Active Streak: 30 Days
Taking a file to it could throw off the balance some, you can check that, but I do not like running damaged props period.
Helmwurst is offline
