Bravo28 - Under-pitched...?
It can be really hard to tell if prop has had work done and it should be if the prop was done right. It could have just been balanced, trued up the pitch and polished.
I'd wait for BBlades winter special.
Deduct 1" of pitch for Bravo props for calculating slip. They are stamped heavy compared to actual pitch. Prop slip still way high. What are your WOT speeds/rpms??
We are typically running 40-42GPS @ 3500RPM, and 75-76GPS at 5100RPM, WOT and trimmed to the ragged edge. With the new prop, we were in the 33-34 GPS range at 3500RPM, and high 50s GPS at 5000RPM, but WAY off the WOT position on the throttle arm. I did not stick it or bother trimming it out.
I've heard that a 28P Bravo, for example, will run about like a Hydromotive 26. Is this because Hydromotive is a bit more honest about their pitch declaration?
Thanks. Brad.
Guys,
I think I found it: Trailing edge cup.
Trying my best to duplicate measuring method and target points…..
Can you tell which one is faster? The older prop has an “X” marked in Sharpie on the hub, right above the “Bravo”. You can also easily feel the distinct reduction in cup in the last half inch or so of the trailing edge of the newer, slower of the two props.
Also found this:
Is that a BBlades documentation number?
Thanks. Brad.
Also found this:
Thanks. Brad.
Griff,
Thanks. Brad.
Thanks. Brad.
Griff,
Kinda what I thought. On all points.
Thanks. Brad.
Thanks. Brad.
