-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Prop Selection help (https://www.offshoreonly.com/forums/prop-talk/380209-prop-selection-help.html)
LTZCrew 08-11-2023 10:58 AM
Prop Selection help
2003 shockwave tremor closed bow
merc ITS with standard lenght bravo 1 XR
re worked 575sci - 825~ hp limiter set at 5900rpms
so far ive tried a labbed 28 B1- spun it right to the limiter
B1 31 pitch*labed 30* with the ring cut down - ran right to the limiter at 89mph
tried a max 5 32pRH 15.75 - wicked cruse but had to run heavy. full fuel and 4 people or the boat would act weird and you could hear the motor load/ un load over the smallest of ripples on the water and had a wicked vibration if i come onto or off plane to slow
max 5 32p LH 15' no weird vibrations and less issues with the loading/unloading but seems to have way more lift, boat wants to walk all over the place as soon as you lean on it
looking to get my slip down and break into the 90's
thinking a 34 or 36B1 is the next bet?? or can a 5 blade be worked to calm this down
seems like the 5 blades just have to much over all lift and get her to be to squirmy.
smokediver 08-13-2023 07:50 AM
You have a nice prop collection going ! I would throw a -2 imco on it. Especially if you added the its at the factory opening. Hate to spend your money but I would guess the standard lower is your issue , especially with the speeds you are running
LTZCrew 08-13-2023 10:27 AM
I was thinking a shorty. But im not sure after running the big diameter 5 blade. With how it reacted to small changes in the water im guessing i was surfacing part of it.
or was that it unloading and spinning to its desired slip?
F-2 Speedy 08-13-2023 10:43 AM
Where is the prop shaft depth in relation to the hull bottom.
boostbros 08-13-2023 08:18 PM
what is the hull like?steps or non? can you spin the engine up to 6500? we run a bit less power but turn it up higher with stock bravo xr on a non stepped 25 foot hull it rips to the high 90s and is stable and predictable and an absolute blast to drive
boostbros 08-13-2023 08:19 PM
we also run a stock bravo 26p prop 4 blade
LTZCrew 08-14-2023 10:06 AM
ill have to measure, i dont remember off the top of my head
​​​​​​​what is the hull like?steps or non? can you spin the engine up to 6500? we run a bit less power but turn it up higher with stock bravo xr on a non stepped 25 foot hull it rips to the high 90s and is stable and predictable and an absolute blast to drive
24* V, single small step - maybe a inch in depth no pad no notch, full length strakes(?) as for RPM never ran it up that high, Dyno shows it started to loose huff at 6k, its still using a modified TBI set up so that's probably all she can breath. there is no lack of power, i can run inot the limiter pretty hard with everything ive tried so far.
im trying to find a out of the box 36p to try but they seem to be imposable to find
is there a way to keep the 5 blade Bite and have its lift more inline with a 4 blade?
LTZCrew 09-13-2023 09:57 PM
Well the 32L 5 blade had to much bite. Couldn't get the rpms up. Ran 81. Didnt seem to carey the boat. Back on the hunt for a labbed 34
SecondWind 09-14-2023 05:19 AM
I would start with a non-labbed 34. If you want a labbed prop lab it for characteristics you desire on your boat.
LTZCrew 09-14-2023 09:55 AM
one thing i did notice and forgot to ask/ mention. with a 4 blade i get some wicked torque lean till i trim out - a lot. the 5blades never did this when matching speed for speed. wouldn't more blades put more "twist" on the hull?
