-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   LH/RH vs RH/LH prop install on twin screw (https://www.offshoreonly.com/forums/prop-talk/382097-lh-rh-vs-rh-lh-prop-install-twin-screw.html)
Griff 04-08-2024 10:51 PM
Originally Posted by imartin (Post 4895055)
https://cimg6.ibsrv.net/gimg/www.off...c98d4659ec.jpg
Confirming port LH-CCW / stbd RH-CW
Team Archer. Would love to add a pic but don't have that level OSO membership....😉
Your props are spinning out. The LH prop is port and RH prop is on starboard.
As far as drive showers, just get the new style Simreks and you don't need to drill anything SIMREK Multiport Drive Showers will cool your Alpha or Bravo stern drive by 60 degrees.
imartin 04-09-2024 05:07 PM
Already picked up the Latham Showers. You're saying mine spin like this...Thank you!
https://cimg1.ibsrv.net/gimg/www.off...ec842daef6.jpg
https://cimg2.ibsrv.net/gimg/www.off...625eeec1c4.jpg
Rookie 04-09-2024 07:28 PM
Correct, spinning out.
im MartinB 04-09-2024 09:52 PM
Me and buddy both tested this at the same time and neither one of us noticed any difference. Same exact top speed. Same manners pretty much everywhere. You only need to shift backwards for the "test". If you decided to switch you just adjust accordingly and then shift normal.
imartin 04-10-2024 03:14 PM
Appreciate the info and assurance everyone! Will leave them ad is and drill hole for pick up tube on inside of each drive. Very helpful group!!!
