Prop Help on Sunsation 29 CCS >
Old 10-05-2024 | 08:19 PM
Default Prop Help on Sunsation 29 CCS
I need some help making sense of my prop situation. Boat is a 2017 29' Sunsation CCX with 200 Mercury Verado's (4 cyl). Boat came from the factory with Mirage Plus 23P props. When I purchased the boat it had 21P Revolution 4 blades. The information below is from the previous owner for the Rev's and the factory for the Mirage 23's. For the Rev 4's its pretty much what i experienced, I was able to get a few more mph out of it vs. what is stated below on our lake. In salt the speed actually matched what is listed below for the Rev 4's and I was bumping the rev limiter on the starboard engine as it kept tapping 6100rpm.
2.08 gear ratio
Dry Weight 4200 lb. dry
Factory Props: Mirage Plus 23P x 14 5/8
Props Spin Outward – Based on gear case can’t be changed unless a new gear cases are installed
Engines were set at the lowest setting
X Dimension: engine set all the way down
25” Shaft length (X long)
Boat Ran 60 MPH on GPS @ 6000 RPM
30 Gal. of fuel
2 ppl
Current Info
Exiting Props: Rev 4 21P x 14 5/8 – (LH Prop out of balance no other issues 9/30/2021 FJ Propeller)
GPS speeds
54.8MPH @ 6150-6200RPM
44MPH @ 5000 RPM
34.5MPH @ 4000 RPM
30MPH @ 3600 RPM
50 Gal of Fuel
Light chop 3-5Mph wind
2ppl on board (450lb)
I bought a used set of Mirage Plus 23's and tested them today on the bay. Boat was actually slower, 3/4 tank of fuel (108 gals) two people and decent chop I could not turn more than 5100 rpm and about 53 mph. End of the day 1/2 tank of fuel flat water 5100 rpm and 50 mph. Tabs were up and engine trimmed to the point of getting loose them two quick bumps down on the trim. I would have thought I could turn the Mirage 23 higher rpm than the 21P Rev 4. What am I missing here ???
bigredbaja is offline
Old 10-06-2024 | 07:26 AM
Rob, I have a set of 23 Mirages, not the + if you want to try them.
snapmorgan is offline
Old 10-06-2024 | 08:24 AM
Thanks Joe, I bought a set not long after buying the boat. Just had the chance to get them on the boat this week and do some testing. I dont understand why I can turn the 23's more than 510/5200 RPM and match the factory set up. Nothing wrong with the motors, they will hit 6000/6100 with the 21P Rev's.
