Formula 242 with high x-Dim. >
Old Yesterday | 01:32 AM
Default Formula 242 with high x-Dim.
Hey Guys,
Bought this boat and did a complete refit. Boat was without power and now its powered by a 502 MAG MPI with stainless manifolds. X-Dim is about 1.5 inch higher as original. Bravo1 drive, 1.5 Ratio.
This was the first test. I have now a Revoloution 4 23p Prop on it.
Boat accellerates and gets on plane perfectly.
2800rpm - 32 mph
3300rpm - 40 mph
3900rpm - 47mph
4300rpm - 55mph --> this is highest speed
This is trimmed ALL THE WAY DOWN. If i start trim her up, i get a massive rooster tail but the boat slows down. I can trim her up to 4800 rpm and she gets 50mph. Feels like the bow does not lift at trim.
Boat has no tabs, driven on a river in fresh water, no chop.
Any suggestions how to improve?
Thanks!
AP700 is offline
Old Yesterday | 07:01 AM
SB
Disclaimer: ibknow nothing about those boats with a higher x than stock.
That said, round table talking….
That prop has a listed diameter of 14.6” diameter. Pretty small for a 502 equipped boat.
The Bravo 22 and 24 have a listed diameter of 15.3”.
Therefore, i’d try (borrow/rent/etc) a Bravo and go from there if need be.
SB is offline
Old Yesterday | 12:43 PM
I'd try a 22 Bravo 1 prop. It will carry the bow more. Also, check the last 4 feet of your hull hook. Hook will act just like dragging trim tabs
Griff is offline
Old Yesterday | 02:02 PM
She has hull hook. I try a bravo1 prop tomorrow!
AP700 is offline
Old Yesterday | 05:15 PM
If a different prop doesn’t get you where you want I’d try a 1 inch spacer and move that drive height closer to where the manufacturer put it.
SecondWind is offline
