Originally Posted by check300
(Post 4055270)
You could always run a dump with an adjustable pressure relief valve.
Originally Posted by offshorexcursion
(Post 4055520)
Craving more pics please!
http://i1202.photobucket.com/albums/...ps16b0cae8.jpg http://i1202.photobucket.com/albums/...psa9084089.jpg http://i1202.photobucket.com/albums/...ps6717e359.jpg http://i1202.photobucket.com/albums/...ps2d4de5d8.jpg http://i1202.photobucket.com/albums/...psc446b93d.jpg |
This is the last you will see of these gear breaking Bravo's! Now that Arneson's are going on! I can't wait until it's all together to see what it is going to be like. I don't know of another BT out there with Arneson's on it, as far as I know this is the first one.
http://i1202.photobucket.com/albums/...ps6734c46f.jpg |
Originally Posted by Jason3603
(Post 4055567)
I do plan to run an air bleed setup off the strainer to bleed excess air, but was thinking of running an 15-18 psi valve. Do you have experience with running this type of setup? If you have, can you tell the pros and cons of this?
(Post 4055841)
I have not used an air bleed but did use a Keith Eickert pressure relief valve. I was able to dump enough water to keep the pressure at 18 psi at over 115 mph.
So... I got the transmissions torn down. Pretty much what I expected them to be. I purchased these transmissions as cores so all in all they are in ok shape. They seemed to of either sat outside or ingested water at one point. There's a lot of rust inside, no biggie. Tear down is always the easy part. Now for the clean, inspect, do a little machine work and re-clean part of the process. As for the mods I would like to do I am still in the preliminary stages of this. Right off the bat there are a couple things that I didn't care for.
http://i1202.photobucket.com/albums/...ps401097c3.jpg |
(Post 4055856)
Thanks for the info. Where did you place the pressure relief valve?
Well.... I got a lot of work done this weekend on the drives and strainers. I cut the tube to 18 inches for strainers, now just have to mock it up in the boat to see if it's taller than I want and layout where all the fittings will be welded. I will post some pics next week when I get back from a business trip.
love these threads, that things gonna fly, im glad you went to bigger blowers with dual carbs, I always feel as single carbs on big ci engine seem to hold back power.
Originally Posted by johnnyboatman
(Post 4062237)
| All times are GMT -5. The time now is 10:19 AM. |
