Eliminator 250 Eagle XP build has started
#91
[ATTACH=CONFIG]517612[/ATTACH][ATTACH=CONFIG]517613[/ATTACH][ATTACH=CONFIG]517614[/ATTACH][ATTACH=CONFIG]517615[/ATTACH][ATTACH=CONFIG]517616[/ATTACH]These are the tabs I'm using, they are marked with green tape. The blue tape is my transom lights mocked up & they are bright! Trying to mount these big amps proved to be a PITA! so I replaced them with Rockfords new amps that are smaller lighter, & more powerful. Along with being easier to wire up. Randy
#92
[ATTACH=CONFIG]517617[/ATTACH][ATTACH=CONFIG]517618[/ATTACH] Couple of pics of where my engine is at right now, shouldn't be too much longer for the updated serpentine setup will be done then hopefully hear it make some noise on the dyno . We are shooting for 850-900hp. Stay tuned. Randy
#93
[ATTACH=CONFIG]517757[/ATTACH][ATTACH=CONFIG]517747[/ATTACH][ATTACH=CONFIG]517748[/ATTACH][ATTACH=CONFIG]517749[/ATTACH][ATTACH=CONFIG]517750[/ATTACH][ATTACH=CONFIG]517751[/ATTACH]My side panels are finally done. After installing my speakers I like the pearl, hooked a 9 volt battery up just to see. Hopefully this will sound good, I am already thinking of mounting the panels on the bottom also instead of letting them hang off the screws like they were. Randy
#94
[ATTACH=CONFIG]518900[/ATTACH][ATTACH=CONFIG]518901[/ATTACH][ATTACH=CONFIG]518902[/ATTACH]Rear seat pedestal got done today, one more piece of the puzzle. I need to set it in the boat now so I can measure how much to take out of the upper seat frame
#95
Got to test fit some interior pieces today for measuring purposes, I have to remove 2 1/2" from the lower part of the upper rear seat frame because the sub cabinet is that much taller. It has been so long since I have seen any interior in this boat I forgot how small it really is. I also have to remove about 2" of padding from the pad that bolts to the engine hatch because the seat is going back to it's original position. 12 speakers & 2500 watts of power pushing them this thing might really kill fish!! Lol and yes I know somewhere along the way the engine hatch got turned upside down so the pad was setting on the floor, my bad. It's being redone but without the extra stitching. Randy[ATTACH=CONFIG]519228[/ATTACH][ATTACH=CONFIG]519229[/ATTACH][ATTACH=CONFIG]519230[/ATTACH][ATTACH=CONFIG]519231[/ATTACH][ATTACH=CONFIG]519232[/ATTACH][ATTACH=CONFIG]519233[/ATTACH][ATTACH=CONFIG]519234[/ATTACH][ATTACH=CONFIG]519235[/ATTACH]
#96
I couldn't stand it, I just had to see what all of this blue lighting looks like so I set it up again & put some power to the lights
[ATTACH=CONFIG]519313[/ATTACH][ATTACH=CONFIG]519314[/ATTACH][ATTACH=CONFIG]519315[/ATTACH][ATTACH=CONFIG]519316[/ATTACH]
#98
Thanks Dave, if this weather would break once and for all I could get it outside & get some floor work done. As it is I have started thinning my fleet by 1 so far, hoping to shed 2 more soon. Randy
#100
Thanks vmf, I hope to get a lot more done this spring & summer. Once I get the floor & transom done the interior will go right in. I will let Maxx know that his twin is boater owned, Lol. I swear if I put paint on his tail he would be more than happy to help. 1st small breed I have owned & I am impressed with him a lot! Randy
