Vinyl Floor Replacement >
Old 03-03-2014 | 06:42 PM
Default Vinyl Floor Replacement
I'm replacing the vinyl flooring in my 2002 Velocity VR1. The old vinyl is white but Lincoin does not come in white any more. I know new boats must use some type of vinyl. Any suggestions would greatly be appreciated.
darobinson23322 is offline
Old 03-03-2014 | 07:04 PM
Loncoin II, birch white
http://www.lonseal.com/show_product/LONCOIN%20II
There's a 12"x12" sample of it sitting on my coffee table as I type this.
Crossett is offline
Old 03-03-2014 | 07:17 PM
That's exactly what I need...thanks. I'll check out the web site.
Old 03-04-2014 | 10:28 AM
Talked to Lonseal today and they advised me that they do not make the exterior in birch white. Still looking....
Old 03-04-2014 | 10:39 AM
Curious what you guys do to trim the edges when you install this flooring?
4bus is offline
Old 03-04-2014 | 11:36 AM
I was unaware there was a difference between exterior and interior applications. That's a shame
Crossett is offline
Old 03-04-2014 | 12:07 PM
Yes, she noted two different inventory numbers and then referred me to Plas Teak to place my order. I informed her that Plas Teak told me they do not carry the Birch White any more.
For my boat the ends are hidden. looks like the manufacture used a razor knife to trim. It's was not a very clean edge.
Old 03-06-2014 | 09:29 AM
Still looking for good quality marine grade vinyl flooring for my velocity. Any recommendations would be appreciated.
Old 03-07-2014 | 07:20 AM
have you check with plasteak.com ? i wanted loncoin too when i replaced my flooring last spring . ended up with white diamond plate .
state1310 is offline
Old 03-07-2014 | 07:21 AM
i was able to trace my old floor with a sharpie and used razor blades
