Upgrading a 260hp 350 >
Old 10-24-2014 | 08:20 PM
  #41
I look at it this way, my current RPM is 4600. With better heads, intake and cam I will be able to spin more RPM, plus with more power who knows what i'll get out of it?? I'd be happy with 55 on GPS
Jonesyfxr is offline
Old 10-24-2014 | 08:32 PM
  #42
Originally Posted by SB
2fastforvortecheads has bigger issues than we thought.
Grab some popcorn and read all this:
http://www.offshoreonly.com/forums/g...please-17.html
And then some searches and you'll see him asking for aluminum prop advice, and then Holley carb tuning advice,,,,,,,,,,but yet, he says he's the exspurt.
LMAOF.
I love u man. U got to get a life man. Most real people ask if they are not sure about something. Unlike u I know I'm not an expert. Since your the best SHOW me where I said I was and expert. Problem is u can't. Since you are ignorant u have to find ways to put others down. This poor fella asked about some help and u got to go ****ing up the thread. Find a big truck open the hood put your head in and SLAM it shut. U got problems you **** for brains.
So2fast5u is offline
Old 10-24-2014 | 08:53 PM
  #43
OK, I'm just gonna ask....please stop.
We are all here because we love boating and speed. We are also here to help each other.
That's why I joined OSO
Old 10-24-2014 | 08:54 PM
  #44
I'm done. Problem is Slow ***** (SB) will never stop till he gets the last word in. He has problems. Good luck with the engine this winter. Keep posted how it turns out.
Old 10-25-2014 | 07:22 AM
  #45
I run a 350ho 330hp vortec motor with a holley 650 carb performer, rpm intake, msd ignition, roller rockers, and revolution marine wet exchaust and I picked up about 7 to 10 mph on a 21 ft hull 24 degrees with a ss prop 23 pitch. good luck
innerrage is offline
Old 10-25-2014 | 06:48 PM
  #46
I just picked up a Vortec 350 short block for $80!!!
Old 10-25-2014 | 09:23 PM
  #47
My Saturday night just got more interesting...
j21black is offline
Old 10-26-2014 | 10:04 AM
  #48
I believe I need to change the flywheel in order to do this engine swap, right?
Everything else should bolt right up.....
Old 10-26-2014 | 05:44 PM
  #49
Flywheel and starter I believe. Is there still a spot for the fuel pump on those late engines?
Was it a boat engine? Changing the cam?
Jeff
hallj is offline
Old 10-26-2014 | 06:49 PM
  #50
SB
If you have a earlier shortblock in good running order, I don't see any reason the Vortec shortblock will be of benefit. IMHO.
Other than that the Vortec will have the hr roller lifter stuff.It will cost more than the $80 you spent on that short block to get that for your 88 motor
Those parts aren't a ton of $$$ new from GM though.
SB is offline
