-   Restorations & Upgrades (https://www.offshoreonly.com/forums/restorations-upgrades-285/)
-   -   1989 Wellcraft Scarab 28 Excel - Restoration (https://www.offshoreonly.com/forums/restorations-upgrades/340159-1989-wellcraft-scarab-28-excel-restoration.html)
Lectronix 01-29-2017 03:25 AM
Scarab 28 - Hull & Deck
3 Attachment(s)
The Hull & Deck from the nose to the end of the cuddy and in the cockpit along the gunwales were glassed together for extra strength and rigidity. In addition, braces were glassed into the area between the cockpit skin and the hull. The boat had a flimsy, plastic (useless) storage compartment. It was removed and a larger, deeper compartment with drain hole was glassed into the location adding strength. It will be carpeted and have LED lighting.
Lectronix 01-29-2017 03:28 AM
1 Attachment(s)
Another look at the 30" Trim Tabs. Will need to jump way out to safely clear the drive and tabs.
Scarab28 01-29-2017 08:27 AM
Any pics of the improved storage compartment?
Looking good so far!
Lectronix 01-29-2017 12:01 PM
1 Attachment(s)
This is it. Port-side of the cockpit below the gunwale. There was only one on my boat; it originally was a form-fitted plastic piece (I don't have a pic of the original but it was lousy). You can see the bottom piece glassed between the cockpit skin and the hull. The front and back are also glassed with a drain in the back. It's deeper and longer than what was originally installed. It'll will be finished in black marine upholstery/carpeting - and there will be a finish trim installed so you don't see the original rough cut. The upper shape you see is how the original piece fit into the section. But this discussion is giving me an idea. Stay tuned!
BenPerfected 01-29-2017 06:46 PM
Great project, it is shocking to see how poorly most of the late 80's preformance boats were built. Nothing $ can't fix!
Lectronix 01-31-2017 01:51 AM
Scarab 28 - Hull & Deck (before & after)
2 Attachment(s)
Here's a before and after photo. You can see Dan's work detail on the hull/deck joint and the improvement over the factory bond.
Dave M 01-31-2017 08:15 AM
Looks nice! I'm guessing you already thought of this, but make sure your prop won't hit the tabs. I had 380's on my Superboat and the plates were notched for that reason.
Scarab28 01-31-2017 04:16 PM
Standing joke was you always tell how much fun my ride was by the number of loose screws holding the rub rail on.
Lectronix 01-31-2017 07:00 PM
LOL, that is funny. Previously I was having to tighten the screws back in all the time; really sucked and looked like the boat was falling apart. Hope that won't be the case now.
Lectronix 01-31-2017 07:02 PM
Yes, Dave. Pretty sure we'll be ok. The box is pushing the drive back and that helps. Was yours a single or twin engine?
