Formula 233  bravo hieght >
Old 03-08-2017 | 01:27 PM
Default Formula 233 bravo hieght
Hello there I am repowering a 1974 Formula 233 with a 454/ bravo does anyone now if or how much I can raise the X dimension? thanks Murray
murray rideout is offline
Old 03-08-2017 | 07:11 PM
i would add :
what 454 model (hp)
intended use (very important)
expectations (hoping for)
this thread may be seen and answered more in another thread, general q&a / drives / formula owners thread, but i dont know which.
mercury says 16 1/8 inches crank centerline (X) on 12 degree transom for b1 and b3, and that b1 and 3 can be raised as much as 3 inches. this is off a paper template i have from mercury. 16 1/8 inches is 5 5/8 propshaft depth below keel b1 is 21 13/16 shaft to shaft.
outonsafari is offline
Old 03-09-2017 | 10:18 AM
454/385 hp boat will be used for general purposes cruising fishing etc. just assumed raising the x dimension would male the hull work better.
