fountain 10 meter race boat
The OP solved it an even better way!
Nice fab on the pipes!.......if your capable, more boaters in this economy should go the way of Bad Chad! where dids you get the SSM 3 decals? ..or were they there previously?
I heard that, so instead we mocked like this and sent it to them (glued and screwed). Made them send the mockups back with the pipes so we knew they didn't screw up. More work but like you said if not, no way do you know you will get what you want.
What cylinder heads are you using on your new motors. Those heads in your mock up have standard Chevy exhaust port heights, hopefully your heads on your new motors don’t have raised exhaust ports .
I beleive they are dart aluminum heads pro 1.Have to call frank at scorpion to confirm" i didnt know they had different ports unless the were tall decks.
