-   Restorations & Upgrades (https://www.offshoreonly.com/forums/restorations-upgrades-285/)
-   -   2007 Mercruiser 496 Magnum MPI performance upgardes (https://www.offshoreonly.com/forums/restorations-upgrades/379562-2007-mercruiser-496-magnum-mpi-performance-upgardes.html)
Planejr 06-11-2023 08:58 PM
I have a 2007 Caravelle 232 Interceptor with a Mercruiser 496 Magnum MPI and a Bravo 1 drive. I’d like to add some horsepower and top speed to the boat. I am considering Raylar’s stage one heads, cam and intake package or something similar. Had anybody on here done a similar build? Or anybody built the 496 at all? Is tuning available for the 2007 Mercruiser MPI system? Thanks for any information and for your time.
techman 06-12-2023 08:37 AM
Raylar kits or Whipple it. However, best to leave the 496 stock if you want any reliability.
87MirageIntruder 06-12-2023 09:52 AM
I've built a few 496s. I went Whipple on them with forged internals. Basically you have to start from the ground up if you want a significant HP gain and be reliable.
The Raylar 525 kit is about as far as you can go on the stock bottom end. The heads are very nice and flow exceptionally well.
Planejr 06-12-2023 01:03 PM
Any particular reason why specific to the 496? I know any engine modified for more power will have some loss of reliability. But I’m hearing what you said from several people and am just curious if there are particular reasons or traits of the 496 that make it extra unreliable after performance modifications? Thanks for the info and your time.
Thanks for the information. How did you tune the PCM on the 496’s you built? Just trying to learn as much as I can before I do something or decide not to do something to my boat. Thanks again for all the good info.
87MirageIntruder 06-12-2023 01:10 PM
I had Whipple do the tune on my builds. It is good to have an AFR gauge so you can give them the needed info so they can dial it in.
The factory 496 has some weak points when it's built up for more HP. The weakest link are the hyperuetectic pistons. The first ring groove is very close to the top on the piston so it's a weak point, and they can snap off the top ring land area. The second weak link are the rods, they just aren't up for high HP. The cranks are strong, even the cast cranks can handle 750hp.
The stock heads have very weak valve springs, like 90lbs of seat pressure, so a spring and hardware upgrade are needed if you go larger camshafts.
You can certainly build up a 496 and they run great, but you should beef up the rotating assembly if you really want longevity. Personally the most I would do with a stock bottom end is the Raylar 525hp kit. This would address the weak valve springs issue.
Knot 4 Me 06-12-2023 01:13 PM
Said piston/rod...
https://cimg4.ibsrv.net/gimg/www.off...109ed64e4b.jpg
Planejr 06-12-2023 05:03 PM
Great info, exactly what I was looking to find out. Thank you.
Planejr 06-12-2023 05:04 PM
Yeah, I’m my opinion that’s a rather spindly looking rod for a big block marine application particularly. Thanks for the info.
Originally Posted by Knot 4 Me (Post 4870403)
Said piston/rod...
