remote oil filter l >
remote oil filter l
remote oil filter l
Old 05-06-2025 | 10:11 PM
scippy's Avatar
Default remote oil filter l
Tired of sloppy oil filter changes that have to stretch over to rear of engine would like to reposition my oil filter to front of engine in a vertical position....what's involved? are their kits for re-positioning
BBC engine to front remote oil filter location
scippy is offline
Old 05-07-2025 | 03:47 AM
You may be able to find a used kit. Not sure on an off the self new kit. You might have to piece one together. Installing with the motor in place will likely be a real pain getting the new oil lines on where the filter was.
Side not, why the external power steering reservoir?
Ryanw10 is online now
Old 05-07-2025 | 05:29 AM
Side not, why the external power steering reservoir?[/QUOTE]
If you have twins and external hydraulic steering and either engine operates the steering then a shared reservoir is required. I found out the hard way. Took a while to clean up.
PQ290Enticer is offline
Old 05-07-2025 | 07:43 AM
Veteran: Army
could be a good time to add an oil thermostat as well, if you don't have one already.
Some options from Hardin: https://www.hardin-marine.com/c-334-...l-filters.aspx
DrFeelgood is offline
Old 05-18-2025 | 11:00 AM
If you use a remote oil filter plate designed to replace the oil filter, you can easily.plumb it to where you want. Not an ideal setup, but it would work. Then tidy it up if and when you pull the engines.
Tartilla is offline
Old 08-28-2025 | 08:43 AM
Veteran: Navy
Jegs, summit racing
have adapters and relocation kits
you may need different hose lengths to get them where you want
powerboatr is offline
