NXT or #6 / Single 24' Eliminator ? >
Old 05-18-2025 | 07:28 PM
why no tabs? we run 380s on a 25 footer they make a world of difference in ever changing conditions
boostbros is offline
Old 05-18-2025 | 09:54 PM
cougarman's Avatar
Can you Eloborate?
I have had V-bottom boats my entire life.
so help on the Cat front is new territory
I would think they would help getting on plane.
I would think they would help control the porpoise.
thank you
Cougarman
cougarman is offline
Old 06-25-2025 | 06:52 PM
Originally Posted by cougarman
Not sure on porpoise cause yet.
only tested twice.
Currently looking for different props to see if transom lift can be reduced or eliminated. Before any other adjustments are made.
It was pushing the bow down & never reached a point of packing enough air to carry it through.
Instead it picked the transom up & side stepped
Been a while. Any testing with different Props? Neat Cat but setting the drive height and getting the right Clever Prop is The Art of the setup. The Magic that everyone talks about but few totally understand with all the variables. I have a New 28 foot Cat hull that is ready for cutting "the hole" so your post is something to learn from for me.
From all that I know, which is not much, but I ask a lot of questions. On a Cat the X dimension is sort of out the door with all the different center to center dimensions for different drives. then add the different extension boxes and all changes if they are used.
To start with adding a box, as you have with a #6, increases the prop centerline height above the kell or lowest point of the hull. So, Yes you are already to low at 1 inch above the kell with a box. It should be up at least 2 more inches, 3 would be better and then add a spacer to bring the drive down if necessary. A lot can be done with Props. What Prop are you running to start with, Dia, Pitch, Rake? Everyone thinks more rake is better but to much will lift the stern right out of the water as you are describing.
LakeBoat4 is offline
Old 06-26-2025 | 05:35 PM
cougarman's Avatar
This is/was Current set up at the start of this thread, obviously to low and causing the bullet on the #6 to act as a trim tab.
We believe it pushing the bow down & picking up the transom
Old 06-26-2025 | 05:41 PM
cougarman's Avatar
Starting over, lets see what we learn
Drive has been raised 2”
We are also going to fill the notch on the center pod which provides another 1”
So, we should be 3” above that bottom with these changes.
this will allow additional testing including being able to space the drive down if needed
Also a few different props to try & see what we learn too
3,4,& 5 blades options along with some different Diameter options too… Being a single Screw
Old 06-27-2025 | 09:03 AM
cougarman's Avatar
Have any photos of your set up to share?
Thank you
Cougarman
Old 06-27-2025 | 09:41 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Not an expert, but I'd consult with https://www.wilsoncustommarine.com/blueprinted-drives
The NXT is known to have a big fat bullet that provides too much transom lift for many boats. The VI drive doesn't do that. But there are tradeoffs. I would think Wilson Custom Marine would be my first call.
Sydwayz is offline
