Originally Posted by pasta
(Post 3442070)
Glad to hear things are moving again. :)
I might have missed something. But, where are you placing the new tank? Under the rear seat bench or in the bildge? How much does the new tank weigh? You have been promising pics for some time now... He he he Let thoose of us who follow you in this thread see what the boat looks like and what u have done with it. :) :) |
had surgery again last week, not planned:angry-smiley-038: but got the gas tank all tabbed in. getting the foam monday and painting bilge. tuesday motor goes in. then we pick up where he left off last aug. running lines for water and oil. hope to have that done in a few days, then elec harness location msd and stuff install konrad drive hook up lines. so 2 weeks should be done. pics I'll try and post this week.but we used kevlar for the double bulkhead and tabbing. and everybody say a prayer for HIGH LIFE Mike lost his life saturday at a get together in Boston harbor in his 27 mag. He was a xracer from the good old days and was very helpful to a lot of people on here. we just got through talking about putting a extra gas tank in my boat, he had 5. God speed Mike
well getting there motor is in now wiring harness then tran and throttle hook ups plus lay out coolers 2 and put them in over the next few days. I owe a lot to Gerry from KNOT RIGHT. thanks pal. its bed time later
OK lets get this fuker floating. Did the sea strainer today couldnt have come out better. Brackets and coolers all mounted and set in place. The trans is hooked up and ready to shift. Oil fittings were hung off the block also.. Installed the block offs in the filetr housing. Ned to get the water pick up in then plumb the water system. Fuel pump and plumbing is needed.
-Mike |
Fuel Lines run last night
Oil lines run last night Water inlet to pump Water to PS/Trans cooler Water to Oil cooler Fuel pump mounted Carb linkage hooked -Mike |
Post some pics of that piece of schit...
Originally Posted by Sick Stinger
(Post 3475164)
Originally Posted by jdub
(Post 3475650)
wow so much for a week, but ITS A LIVE. Gerry took a vid today cause I forgot my camera, so sunday I should have pics posted and vid by monday. man this is a BEAST ,I never had my ears ringing from a lil blurp of the throttle off idiol to 3800rpm wow. blower surge is 600 to 1100rpm sound just nasty with 5'' tails and 2 1/4 id header runners = about 2/3/4''od wow.hitting water this week to see what a 17 1/2'' X =3'' drive shaft height will do on a SABER28:evilb:. I think fine since Boxer raised his without a box to 3 3/8'' and picked up more speed mid 90s in a 31 sutphen 950hp. I hope the saber goes much better with the konrad ace xfactor drive. wow 1 year and 11 months. this spring need to add bigger or mod bolsters and cut outs for legs and extra gas tank.:bigbird:
cool.... we need PICS! i always liked that saber!
| All times are GMT -5. The time now is 01:19 PM. |
