-   Saber (https://www.offshoreonly.com/forums/saber-201/)
-   -   28 Cyclone Power Twins (https://www.offshoreonly.com/forums/saber/356627-28-cyclone-power-twins.html)
TexomaPowerboater 10-05-2018 09:28 AM
Thank you!
hotjava66 10-06-2018 05:54 PM
Based on what I have heard and checked into when I had my 28 it will probably take 750 a side minimum to reliably break 100.
RBeyer 10-06-2018 08:45 PM
Originally Posted by TexomaPowerboater (Post 4652714)
Can any of you 28 Saber owner's help a brotha out and let me know the max height the boat is on a trailer. Also, please state whether or not your trailer has torsion axles or not.
I've never had mine in the garage but with spring suspension and the cover off it would fit in my 7' Door.
FunHome 10-23-2018 09:15 AM
Originally Posted by RBeyer (Post 4648910)
What have you guys done for power with your 28 Cyclones with twins and what were your top speeds? I understand Purple Haze spent much of it's life with 1100's does anyone know how fast it was?
I've got the only 28 Cyclone with twin Small Blocks. The Motors are 383's and are putting out +- 450hp. I'm running bravo drives with -2in Sportmaster lowers and a pair of labbed 30p Bravo 4 blades. I ran 85mph on Radar at the LOTO Shootout this year. (82 on GPS) In years past with different set ups I have seen a little more speed with -2in Imco lowers.
RBeyer 10-23-2018 11:40 PM
I'm right there with my current setup. 525SC Hawks spinning 30 Bravo
RBeyer 10-23-2018 11:43 PM
I think 750 a side should easily break it. I was thinking 650 a side should be there,
hotjava66 10-24-2018 11:12 AM
There have been a couple of boats with 650 a side both ran low to mid 90's from what I have heard.
RBeyer 10-26-2018 10:21 AM
Thank you, it definitely takes big power.
FunHome 11-01-2018 12:58 PM
I suggest you talk to Doug.
I love my boat, and I would like to get it to 90mph. But 100mph in a 28ft with a rounded keel is going to be a handful!!
SABER28 11-01-2018 04:30 PM
i found that just a little tab touching the water stabilizes it out nicely.
