Go Back  Offshoreonly.com > Owners Forum > Saber
Purple Haze >
Purple Haze
Purple Haze
Old 07-15-2020 | 09:23 PM
  #31
Originally Posted by RBeyer
HP and TQ curves crossed right at 5300
interesting fact, every internal combustion engine crosses hp and torque at 5250
Unlimited jd is offline
Old 07-15-2020 | 11:27 PM
  #32
well i guess looking at the simply the graph and not the numbers 50rpm is pretty close. That is an interesting fact though.
RBeyer is offline
Old 07-16-2020 | 10:47 AM
  #33
Have you tried running 3 blade props? I know everyone turns their nose up at them these days but as low as the drives are on most 28's they do work better imho. Slip #'s on my 28 were crazy low with 3 blades and they were significantly faster. Yes, you can't hole shot like a drag racer with them but they also had less tendency to porpoise at cruise. Would be worth at least testing a set of old school 31 Mirage if you can put hands on them.
hotjava66 is offline
Old 07-16-2020 | 11:43 AM
  #34
They are hard to find and don't know if a 31 would be big enough and I boat on short lakes so I don't think I have enough room to use run them out. These 32s seem to be a great baseline and should work with a little tweaking. I need 100 to 200 RPM to be where they want me. I understand just removing the diffuser ring will give you 150. It really needs -2" shorties just cant make that work until maybe over the winter. Hard to ***** about low to mid 90's
RBeyer is offline
Old 07-16-2020 | 05:55 PM
  #35
Yeah thats a nice number. Would keep eyes open for a set of 31's if you can buy right, was told they are actually more like 32's or 33's might be the ticket. I thought hard about shorties, I don't know if these hulls like them after asking around, same with extension boxes. With the rocker built into these hulls you need enough leverage to carry the bow or they will want to hop.
Old 07-16-2020 | 10:19 PM
  #36
The 32s seem to have gotten rid of the porpoise at low speeds even with trim up. it is carrying the stern well. If it does start to bounce a quick bump of the throttles or a trim adjustment take it right away. Seems to be coming together nicely. I think the shorties would be nice for taking away a bit of bow lift. I would love to try them.
RBeyer is offline
Old 07-19-2020 | 01:05 PM
  #37
SABER28's Avatar
hotjava66, do youknow you drive height? or at least the distance from the rubrail to the top of the transom assembly? curious as mine has the hatch raised two inches so im wondering if my height is raised. might have to call doug.
is anyone interested in a saber rally? the old ones were fun.
SABER28 is offline
Old 07-20-2020 | 09:53 AM
  #38
I dont have the boat anymore but I can tell you my hatch was not raised and prop shift centerline was about 6.5" below the bottom at drive location using a long straight edge
Old 07-31-2020 | 09:55 AM
  #39
FunHome's Avatar
Interesting, I have a set of 27p 3 blade Mirage props. I've heard of the 29p Mirage 3 blades, but I did not know they made 31p 3 blade Mirage props.
FunHome is offline
Old 09-11-2020 | 03:31 PM
  #40
32 4 Blades with a little tweak are the answer, Thanks all!
RBeyer is offline
