-   Scarab (https://www.offshoreonly.com/forums/scarab-41/)
-   -   Engine mount loose - how to fix it? (https://www.offshoreonly.com/forums/scarab/134845-engine-mount-loose-how-fix.html)
satisfactionII 07-10-2006 05:31 PM
I noticed that my port side engine mount is loose. I tried to tighten the bolts but both seem to be stripped. The bolts that hold the mount appear to be going into the stringer. What is a good way to fix this without pulling the engine?
SAR
jhiguy377 07-11-2006 04:14 PM
Re: Engine mount loose - how to fix it?
sat.,
had that problem in an old formula; used epoxy for a temporary fix. ultimately i had saddle mounts fabricated and sidebolted mounts to stringer as opposed to lag bolting into top of stringer. good luck -jeff
eyezlee 07-11-2006 08:11 PM
You may want to post this out in GD or technical discussion. I'm sure the Scarab forum isn't visited much.
satisfactionII 07-13-2006 12:29 PM
Thanks Eyezlee, I noticed that.
superwrench0166 07-13-2006 06:06 PM
Rot
satisfactionII 07-14-2006 09:46 AM
Originally Posted by superwrench0166
Rot
Super OUCH! The whole engine compartment is enclosed with this boat and gelcoated etc. Wonder how I am going to get into this to do a complete repair? Just start sawzalling ? :(
bam7722 10-05-2006 11:41 PM
Thats what I began to do, and now im into it for the transom as well....plus all 3 engine compartment stringers AND the the bulk head, AND the four stringers behind the bulkhead I "blocked" which is a new system of replacing portions of stringers with out tearing the glass out of the boat...
bam7722 10-07-2006 12:49 AM
In doing what? there is no chance of my stringers re-rotting. I made well sure of that. The stringers to the front are all dry. I made sure of that.. my boat builder friend said to run the boat with the transom like it is for a year or 2 but im not takin the chance. I do not want to put my family on something thats water logged. Does anyone have a scarab 400? what is the difference between that and the scarab III??
